Nützliche VST-Plugins
Erst einmal ist das hier nur ein Notizblatt über Software, die ich ausprobiere
ADHDidi
ADHDidi is an additive synthesizer comprising of 16 sine waves tuned to different frequencies (fundamental plus the first 15 harmonics).
XenFont
XenFont is a two oscillator, hybrid SF2 SoundFont & Subtractive Synthesis VSTi that features full-controller MIDI Pitch Microtuning using the MTS (MIDI Tuning Standard) format, where any MIDI Note Number can be freely microtuned to any desired pitch across the MIDI range, enabling computer musicians and composers to explore the vast expressive possibilities of composing music with alternative intonation systems.
XenFont is a microtonal sound-designer’s SF2 sample-based synthesizer, with a carefully designed ergonomic workflow for quickly creating powerful sounding and musical useful timbres. The instrument enables users to load their own SF2 SoundFont files and thereby any special timbres required of the music at hand, from classical acoustic instruments, to synthesized ones. Routing the SF2 SoundFont Oscillators through the internal synthesis functions of the VSTi, provides a way to radically transform the original sounds and create new synthesized timbres.
XenFont is also an educational tool for learning about computer music sound-design, sampling and subtractive sound synthesis, as well as musical instrument intonation (aka microtuning and xenharmonics).
